Set x scale of wavefprm graph
Hello..............I want to set x scale of waveform graph in month name . I tried for that using Advaced editing mode and set into format sring but that shows invalid. So please give me suggetion for set x scale of waveform graph in month name.
(2,376 Views)
Accepted by topic author shubhangi
The reason for your failure may be, you are not following required syntax for format string.
Try this .... Probably it should work for you.
Devang
(2,365 Views)
It is working...
Thank you.......
(2,355 Views)
