SetBlockParamValue.vi
I am looking for these subvis- SetBlockParamValue.vi, LiveSensor.AccessOutputPort.vi. where can i find them?
Thank you
Nabila
(3,863 Views)
Hi Nabila,
Can you provide more information about your application?  Is this an example program that you are trying to open but can not locate those VIs?  When are you getting the message that you are looking for these VIs?  Thank you for the additional information.
Kira T
(3,837 Views)
Yes. the attached files are asking for these missing vis. This is for a fergilli's linear actuator.
Thank you
Nabila Salma
(3,832 Views)
Do you have the NXT Toolkit?  Without that toolkit, you won't have those VIs.
(3,829 Views)
I have NXT toolkit. I still cant find those VIs.
(3,823 Views)
Did you install the toolkit after installing LabVIEW?  Do you have multiple version of LabVIEW on the machine?  Are the toolkit VIs in the palette?
(3,819 Views)
