Setting ActiveX property
I have several interface properties in my ActveX component. I have a property, say, MyProp. To get and set the property I have defined the standard get_MyProp and set_MyProp methods.
However when I try to access it from Labview, it doesnt support set functionality and supports only get functionality.
Is there a workaround?
Thanks in advance
(2,644 Views)
You might want to make sure the method works if you try to use your component in visual studio first. Make sure you have at least LabVIEW 5.0.1 or later. Also, check out this Knowledge Base and see if what it says applies to you.
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/fa815fffe728a050862566db006cc139?OpenDocument
(2,644 Views)
