Setting Cycle stop for a while loop
I have built the block diagram below for a Modulo 6 counter and I want to run it 7 times and only 7 times. As it is now it runs infinitly and makes it impossible to get the data I need.
Is there a way to set the loop to run once?
Thanks.
(1,399 Views)
Hi Cw,
When you know how many iterations your loop should run then you should use a FOR loop instead of a WHILE loop…
Or employ polymorphism:
(1,391 Views)
