Setting History size of rolling graph
How can i set the history size of a rolling graph dynamically
by code ?
Thank for your helps.
For french reader :
Je souhaiterais pourvoir changer la longeur de l'historique par code
mais je ne trouve aucun attribut lié à cette propriété du graphe
déroulant.
Merci de votre support !
(2,691 Views)
[posted and mailed]
crafton@noemail.no (Crafton) wrote in <39B50C9E.9300D7F4@noemail.no>:
>by code ?
Don't think you can, however you can create a FIFO buffer using a LabVIEW 2
global (uninitialsed shift register; USR) and re-plot your data on a
different graph type.
Alexander C. Le Dain, PhD
ICON Technologies Pty Ltd
http://www.icon-tech.com.au
(2,691 Views)
