Setting Limits on a real time XY graph
I have this XY graph with some real data.
The limits were established prior to the WHITE lines have been drawn on the graph.
That is leaving me with all kinds of FAILURE because of the existing test.
Sometimes the motor is running too slow, grabbing too few of a data. Sometimes its too fast grabbing too much of data.
Can I set the limits somehow were its more dynamic? As in, when the end slope is starting to ZERO out when where THE LIMIT line ends?
Can someone guide me in the right direction.
I am using Labview 7.0
I can open with Labview 8.0
please help.
Thank you
Krispiekream
Message 1 of 10
(5,122 Views)
...you may want to ask an operator to move your post to the more appropriate LabVIEW forum Smiley Wink
Message 2 of 10
(5,111 Views)
sorry. I didn't realize I posted in the wrong forum.
thanks!
Krispiekream
Message 3 of 10
(5,098 Views)
please help.
Thank you
Krispiekream
Message 4 of 10
(5,120 Views)
Sure, create the ramp with say 170 points (instead of 220) currently.
Initialize array of length 50 with value of last point
Build array to combine them.
Message 5 of 10
(5,113 Views)
I am not sure if 170 is a good number or 220 is a good number.
for this set of values. 170 would be a good number. But in other runs, 220 would be best.
I don't want the function to have a set 170 or 220 value.
how would I implement the algorithm to set the set of points based on when the slope begins to ZERO out.
In this case.
around 70 and 280 would be good starting points?
Krispiekream
Message 6 of 10
(5,102 Views)
You can use the "Derivative x(t) " VI to see where the slope is greater than a certain threshold.
Message 7 of 10
(5,089 Views)
I have tried using "Derivative x(t)"
but I think I used it wrong so it only show me index 0 as the first derivative of the array?
Krispiekream
Message 9 of 10
(5,021 Views)
It should return an array to you. If you just use index array, it will return the first value. If you reverse the array and then use index array, it will give you the last value.
Message 10 of 10
(5,013 Views)
