Setting Timer to Sequence Structure
I'm currently designing a VI that perform analog data acquistion. How do I actually set a timer to each sequence so that they can run within stipulated time??
(2,882 Views)
One of the methods you can use is to modify timed while loop. I'm sure there will be some other way out there.
(2,882 Views)
One of the easiest ways is to use the "Wait until Next millisecond" VI. Just place it in one of your sequences and program control will wait that long to execute the next sequence.
J.R. Allen
(2,882 Views)
