Setting Windows Short date and time formats from Labview .
Hi .
I am using Labview to retrieve some data from an Access database. In the
Access database the date time field is in the format I need to use
02-Jan-2001 12:00:00. However if the windows regional settings are set to
something else. The database date time stamp is returned in the system date
time format. Has anyone got a VI that will set the Windows System date and
time format?
Regards
Leo
(4,419 Views)
Yes, I've run into this too, while using the SQL Toolkit to manipulate an Access 97 db. The problem arises when you retrieve a date/time field - which must be returned as a string. You want to parse the string so you can convert it back into a LabVIEW floating-point numeric date/time, so you can do date/time math. But you can't do the Scan from String reliably if the Windows Regional Settings are changed, which any user can do.
For this, I wrote a couple of VIs which call the Windows 'SetLocaleInfo' API function from kernel32.dll and force the date/time picture into the ODBC-semi-standard format of 'yyyy-mm-dd hh:mm:ss'. I've attached a LV5.1 LLB which ought to help.
Hope the file attaching process works - haven't done this from the DevZone website be
fore. If it doesn't show up, I'll re-send to Leo's e-mail.
David Boyd
Sr. Test Engineer
Abbott Labs
(lapsed) Certified LabVIEW Developer
(4,419 Views)
I just made a VI (in LabVIEW 6i) that gets or sets the system time format using the Get- and SetLocaleInfo Win32 API function calls. A 'Set?' boolean controls whether to read or set the date format. I preset the date format to 'dd-MMM-yyyy hh:mm:ss' to match the 02-Jan-2001 12:00:00 you showed on your posted question.
Hope this helps!
John Wilson
Sanders Engineering & Analytical Services, Inc.
Mobile, Alabama
johnwilson@pctechnician.net
251-633-4120
(4,419 Views)
