Run this VI 2 or more times and you will see it perform as I intended it to i.e. the lines containing the word red show up in red, and the remaining lines show up in black. However on the first run after the front panel values are reinitialized, the output string shows up completely in black.
I'd appreciate any ideas on how to get this VI to work.
	S G
Certified LabVIEW Architect, Certified TestStand Architect, Certified Professional Instructor
