Setting active field
Is it possible to programmatically set the active field to a string control box so that the cursor is already in place and the user does not have to select the box with the mouse in order to start typing into it?
(2,889 Views)
Accepted by topic author JennyT
First there is setting the "Key Focus" to true
If TRUE, the control has key focus and receives the keys pressed on the keyboard.
Then there is Text.Selection:Start and :End if you wish to highlight and over write what may already be in the string control
Omar
(2,882 Views)
Thanks for the post Omar!
For anyone who is a little less familiar with where to find the "Key Focus" or the "Text.Selection:Start" or ":End", it is a property node created from the string control in the block diagram. The picture attached here shows where to find each of the property node options.
Kim W.
(2,847 Views)
