Setting baudrate on a PCI-CAN/XS2 board in LabVIEW
Hello!
We are using two CAN-boards and we want to be able to choose baudrate between 250 k and 125 k with a menuring. Is it enough to set the board to "high" -speed and then change the Baudrate in "CAN Network Interface Config" ? If anyone has an idea we would be greatful. We only have a system that runs with 250 k but want to have the opportunity to run a system with 125 k in the future. So we can not test this right now... that is why we wonder.
Thank you and best regards.
(2,459 Views)
Hello Ex-jobb
Yes, that's essentially it. Look at the attached code. I modified one of the examples to use a menu ring instead of a numeric control to set the baudrate.
-B2k
(2,455 Views)
Hello!
Thank you very much 🙂 That was just what we needed to know!
Thank you again and Best regards
(2,451 Views)
