Setting controls on particular tab page to default value with one invoke node only
I dont know weather it's possible or not, i want to know like we are having invoke node with the help of which we can set all the controls and indicator on front panel to their default value, same way is it possible to set the value of controls and indicators for a particular tab page to their default value without using separate invoke node for every control and indicator.
Message 1 of 9
(3,763 Views)
Thanks KrzysztofSzewc for reply,
The Link that you have send is to set the values for all the controls and indicators on front panel to their default value, i want to ask is it possible that like we use tab control and on different pages we have different controls and indicators, so how can we set the value for all the controls and indicators on particular page(e.g Page1) to default without using separate invoke node for all
Message 3 of 9
(3,749 Views)
KrzysztofSzewc
Sorry, i noticed the second link now only, i will try this.
Thankyou
Message 4 of 9
(3,747 Views)
sorry I forgot to add 2nd link. Now it should be clear for you 🙂
http://www.krzysztofszewczyk.net
Message 5 of 9
(3,746 Views)
KrzysztofSzewc…
with the help of the second link i am able to make the controls/indicator on tab control to their default, this link is working for me correctly but still i want to know one thing this is setting all the controls and indicator present on every page to deafult, can we make it for one particular page only.
Message 6 of 9
(3,731 Views)
So you have TabCtl and on output you have Array (pages), so Im thinking if you index this array (select one index for example 1 wich is page 2) and remove first for loop it should do the work 🙂
Message 7 of 9
(3,722 Views)
i tried indexing the array and removing for loop but that way it is not working,
i am attaching the image of what i am doing
Message 8 of 9
(3,712 Views)
look at my previouse post 🙂
Message 9 of 9
(3,709 Views)
