Setting current values as default.
Hi there !
I got a VI that is suspend when called.
I make the right settings, and then I run the VI (settings are written
trough GPIB to a HP4145A)
It would be nice if I can make a checkbox or something, when this box is
checked, that all the current settings are set as default. So when I
call the VI next time, I got the previous setting. I've searched LabVIEW
help and menu's, but didn't find a thing.
Anybody suggestions, tips, ???
(2,977 Views)
You can save the settings in a file and load them again, if you need.
Kristof Poppe schrieb:
> Hi there !
Ingenieurbüro Mencke & Tegtmeyer
Laubbreite 21
D-31789 Hameln
Tel. 0 51 51 / 96 33 68
Fax 0 51 51 / 96 33 69
e-Mail: menckeundtegtmeyer@t-online.de
(2,977 Views)
you can use the VI Server VIs to make current values default and save the VI.
Stu
(2,977 Views)
here is an example on how to do that using VI Server
(2,977 Views)
