Setting out a spreadsheet inluding description of AI channel and Timestamp
I am recording 128 anologue channels and would like to have a spreadsheet (name of spreadsheet file given by looking in the contents of another file i.e file.txt contains 1234 therefore spreadsheet file is called 1234.txt) which has the channel name (AI0 = name given by virtual channel already defined i.e css_L1_01) at the top of the spreadsheet and a timestamp for each sample (as below)
Time/s css_L1_01 css_L1_01 css_L1_01
0.2 5.12 1.34 2.4
0.4 etc etc etc
0.6 etc etc etc
0.8 etc etc etc
I am doing this in a while loop so I could use the increment counter a
nd times it by the time per loop (200ms) but I am having difficulty geting a proper output.
To summarise I would like to be able to get the virtual channel names and put them on top of the data aquired and I would like it timestamped and the spreadshhet given a name which is aquired by looking at the contents of a file.
I have been trying to do this for days with no luck!! Any help would be most appreciated
Dave
(2,700 Views)
Hi Dave
Try this, I use a csv format, but you can modify it for your requirements. The file containing the filename assumes there is no file extension.
(2,700 Views)
Thank you very much. When you see someone else do it it seems so easy and yet it would of taken me weeks to get close!!!!!
Nice
(2,700 Views)
