Setting position for multiple cursors
I have a question regarding the XY-graph in Labview.
I would like to set 2 cursors in the graph and program their position in the block diagram. When I try this, the "Property Nodes" only sets one of the cursors in the correct position. The other one is stuck at (0,0).
Is it possible to use 2 different Property Nodes that controlls each of the cursors? And how do Labview know which of the cursors thats connected to which Property Node?
Best Regards, Emil
(3,601 Views)
You must use the Active Cursor property node to change the active cursor before setting its position.
(3,597 Views)
To elaborate on JB answer :
use a loop, to set active the relevent cursor before setting its position.
Message Edited by Gabi1 on 02-21-2008 02:59 PM
... And here's where I keep assorted lengths of wires...
(3,582 Views)
