Setting the Serial Start Bit?
How can you set the Start Bit using NI-VISA ?  If you can't do this thru LabVIEW, how can you see what setting is used???
(7,219 Views)
What do you mean by "setting the Start Bit"?  I don't think there is any setting.  A start bit is just a start bit.  You can change the # of stop bits to 1, 1.5, or 2 and you can do that in MAX and with the VISA configure serial port function.  (where 10 means 1, 15 means 1.5, and 20 means 2)
(7,203 Views)
Yeah, you are right.  I just talked to a Hardware Vendor and he said start bit is always there, and not configurable.  It is what tells the terminal how wide the bits are, etc.  Thanks anyway!
(7,199 Views)
Seems about right. I found this KB:  Measuring the Output of a Serial Port for Low Level Analysis. If you take a look at the examples at the bottom, it just re-iterates what you said earlier.
Nick D.
Message Edited by Nick D on 05-22-2007 01:38 PM
(7,175 Views)
