Setting the color (or background color) of a substring
Is it possible to set the color of a substring. For example:  If I had the string "Steve is stuck and needs help" and I wanted to change it to become "Steve is stuck and needs help".
At present I am trying to modify the text inside of a String Indicator, but am open to suggestions.
I have been reading the LV help and it seems to suggest that you can do this using the Text.SelStart and Text.SelEnd properties, but I can't get over that last hurdle that actually updates the string.
Regards
Steve
(2,701 Views)
Accepted by topic author SercoSteveB
After setting the Text.SelStart and Text.SelEnd, use the Text.FontColor to set the color of the selected text. Text -> Font -> Color.
(2,696 Views)
The property you want is Tect -> Font -> Color.
(2,693 Views)
So close.
Thanks All
(2,687 Views)
