Setting thermocouple type in scan engine
I am using cRIO 9211 to acquire thermocouple data using NI Scan Engine. I don't see any option to specify the type of thermocouple other than by right clicking on the module (in project) and selecting Properties.
Is there a way to programmatically set the type of thermocouple?
If this is not possible, can I can read the cjc and offset channels, so that I can convert the raw voltage to temperature in my RT code?
Will I be able to read the cjc and offset channels if I use NI Scan Engine Advance I/O Access?
"A VI inside a Class is worth hundreds in the bush"
യവന്‍ പുലിയാണു കേട്ടാ!!!
(3,009 Views)
Cross posted here.
(2,976 Views)
Yes ,
Please check the link directed as -
http://forums.ni.com/ni/board/message?board.id=280&message.id=5141&jump=true
as do let us know for any further issues .
Pranchal
(2,939 Views)
