Setting to do in window PC, for that only Labview code runs on it
Is there any setting we can do in Window PC so that when it starts only our Labview installed prgram runs on it, nothing else.
In Window startup, it can be done to load labview program when window starts.
But I want that no other program to run on it by user, only labview code.
(2,679 Views)
If you build an Application (.exe) in LabVIEW, you can use Windows' "msconfig" to make this Executable run when Windows starts.
Bob Schor
(2,647 Views)
What you seem to be looking for is called "Kiosk Mode".
The implementation and functionality varies for different versions of Windows.
Search for "Kiosk Mode Win XX" where XX is your windows version.
There are some 3rd party tools available.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(2,604 Views)
