Setting typedef to a cluster
I`m using an IMAQ Edge find tool. There is ROI descriptor connected to the IMAQ Edge find tool. I need one value in the ROI descriptor to be variable. How can I do it? First idea: build your own ROI descriptor from basics. I tried it but still getting error:
The type of the source is 1-D array of
cluster of 2 elements.
The type of the sink is typedef 'ROI Descriptor'
For better understanding about the issue one shall look at attached screenshot.
Do you know how to set a typedef to a cluster? Or do you any other ideas how to solve mentioned issue?
Thank you a lot!
(3,435 Views)
Accepted by topic author xombox@seznam.cz
Hi xombox@se...,
use the "bundle by name" function and connect your values. Use the constant as input to the "bundle by name" function.
Mike
(3,424 Views)
Mike, thank you for pointing me to the right direction. It worked!
I attached solution screenshot for the others with similar problem.
Just a small question: is it possible to put all this set ROI to one element (I measn this ROI being represented only by one icon) so that my labview code is more well-arranged and readable?
Martin
Message Edited by xombox@seznam.cz on 05-03-2009 08:56 AM
(3,379 Views)
Hi Martin,
you can create a subvi.
Mike
(3,357 Views)
