The other things you need to be concerned with are security and firewall configurations for the module.
For security, if you are using a FP-1600, security is added on in firmware revision 0410 downloadable from ftp.ni.com/support/fieldpoint/Update/FPEthernet0410.zipand FieldPoint Explorer 3.0.0. For FP-20XX series modules, security is supported in all released versions.
For information on configuring firewalls for use with FieldPoint Ethernet Modules, please look at the following document. Whereas the title implies that it is for Lookout and the LabVIEW-Datalogging and Supervisory Module only, the information also applies to FieldPoint Ethernet systems.
http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/7d0e7f20b1a7c8e486256a39005747
f2?OpenDocument
Aaron
LabVIEW Champion, CLA, CPI
