Setting up a Database through ODBC from within a program
I am using a access database to store data which is coming from several PC using Windows OS. To reduce the maintenance I would like my program to check the connection to the Database and if it does not exist, cerate it automatically within the ODBC. Has anyone found a solution to this problem?
Message 1 of 1
(2,646 Views)
