Setting veritcal and horizontal scale/position
Is it possible to automatically configure vertical (voltage) and horizontal (time base) with and External input trigger (DC - 3GHz)...
Basically, try to capture waveform by preventing vertical 'clipping' and the scope take measurement at some specific time relative to the trigger event.
Does anyone have an experience to set a similar scope (TDS 8000)?
'Do scope Setup_mod.vi' is a part of subVI for scope setup.
::using LV 7.1 in W2K pro
(2,676 Views)
Unfortunately I do not have an answer to your question.  The instrument driver for the TDS 8000 is provided by Tektronix, so you may be able to contact them regarding its use.
Jason S.
(2,660 Views)
