Setting webserver settings project specific
The Webserver settings are set in the project explorer (or in the VI) in the Tools/Options menu. However, the settings do not only apply to that VI or project but also to any other project that is opened afterwards. Is there any way that these settings can be truly project specific and only apply to the selected project???
(2,883 Views)
The Tools -> Options... settings apply to the LabVIEW environment.  Some of that information is stored in the labview.ini file.
You should be able to enforce VI-specific settings by programmatically setting those configuration properties.
Generally with LabVIEW we take programmatic action on the development environment or a VI through VI Server - property and invoke nodes.
Here is a screenshot of a property node exposing choices for an application reference under the web server category to get you started.
I hope this helps!
Best Regards,
JLS
Message Edited by JLS on 01-29-2007 10:17 AM
Best,
JLS
Sixclear
(2,875 Views)
thanks for the info
(2,865 Views)
