Setting window positions at startup of Labview
Is there a way to set the window positions of the front pane and block diagrams when I start a new VI or when I look at an example (not at runtime of VI)?
(2,744 Views)
Hi JPDel,
yes it's possible with VI Server functions.
There are also some std vi's which will be called in defined situations. I don't know the link, but i know there exists a document written by Jim Kring about it.
Hope it helps.
Mike
(2,724 Views)
Thanks!
(2,704 Views)
