Setup SSL certification in LabVIEW2010
Hi everyone,
i've build up a Web Service on LabVIEW 2010, i want to change the connection using SSL (HTTPS).
I found the article from Elijah http://decibel.ni.com/content/docs/DOC-5941
I've tried to enable SSL on my PC but the option on the Web server setting return no result as i query for the certification. And on the web page configuration doesn't allow me to use SSL because SSL is not activated.Webeinstellung.png
So what is the right way to enable the SSL for the web server?
Wilbur
(7,382 Views)
Hi Wilbur,
click on configure Web Application Server and Enable SSL (see screenshot).
The come back to the LV option give the path of the certificate and click on Query.
You see that the certificate is shwon in the pulldown menu "Discovered Certificateswebserver conf2.PNG"
 I hope it helps.
 Best regards
 Andrea P.
(7,338 Views)
Thank you, Andrea!
I'll try and post result here.
Wilbur
(7,331 Views)
Hi Andrea,
I've tried exactlly what you described. By pressing the Query buttom I could find the certificate file.
However, after i press ok to close the "Options" panel LabVIEW forgets what happened and the "SSL certificate Files" turns back to be empty.
Surely it turns out to be error when I try to access Https adress!
How should it remember what's happened by query?
(7,316 Views)
