Setup of OPC server
I am trying to setup a OPC server binding to the SVE engine on another pc. But the items in the OPC server cannot be read.
Please see the attached screen shot for the reference.
Any suggestion?
(2,765 Views)
Which OPC-Server are you using? Maybe it is a windows problem because you have to run the OPC-Server as a service to communicate with the SVE. The Kapware OPC-Server works like this.
I am not sure if I unterstood you correctly: You want to make an OPC interface between two machines which have the SVE - is it correct? Why aren't you directly binding to the SVE from the destination machine?
HTH
Kind Regards,
Joachim
(2,750 Views)
