Several frequency-signals by function-generator.vi to an ECU (CAN)
I´m trying to send several signals (square, sinus with different frequencies) to an DCU over CAN.
But its not possible for me. I never can send more than one frequency and also just one signal-type.
Can someone show me, how it is to program (now  I`ve a loop with an sequence; and every sequence-block send different frequencies...but the times and signals are all wrong)? For example, how to program 2 or 3 different signal-types and frequencies in a loop, so that the signal would be send permanent to the CAN-PCI-Card.
Thanks a lot.
tancris
(2,282 Views)
Hi Tanchris!
Is it possible for you to post your VI so we can see what you are trying to do?
  Georg
(2,243 Views)
