Seyonic Pipetting System
Has anyone sucessfully used LabVIEW to interface to a Seyonic pipetting system?
(3,915 Views)
Hi pcardinale,
What communication protocol are you using to connect to this device? (serial, GPIB, etc.)
-Matt
Matt
NI Community Team
(3,894 Views)
The device uses RS-232, but the provided documentation is only for the .NET interface.
(3,884 Views)
Is this documentation what ships with the product?  Do the .NET examples call into any dll libraries, or are they .NET assemblies you can call from Labview?  Or do you have the programming guide to the device so that you can just send the commands via VISA through the serial port?
Jensen
(3,861 Views)
The documentation is what ships with the product.  There is no programming guide for sending commands through the serial port.
The example code is Visual Basic calling .NET assemblies.  I have tried to create equivalent code in LabVIEW, but without success.
(3,831 Views)
Here is some informaiton about calling .NET assemblies in Labview.
Using .NET in Labview
Using .NET assemblies with Labview
Loading .NET 4.0 assemblies in Labview
If you can't get the assemblies to work you will need to see if you can get directions for programming it yourself and use Serial or CAN commands to communicate with the device directly instead of through the assemblies.
Jensen
(3,812 Views)
