Shaft Profile
Hi
I will be acquiring thickness measurements of a shaft using sonar caliper, take about 8 readings around the circumference, go down few centimeters and again take the 8 readings and so on .
The actual data is not available yet, I will start with making simulated data.
I would like to make VI that plots the data to get representation like on the picture below
The question is: Could you please give guidelines to start this task
Now I am playing with the 3D surface VIs and trying to figure out how my data flow will be
Much appreciations
Shaft
(2,962 Views)
(2,950 Views)
Thank you
I am looking at it
(2,923 Views)
