Shape detection for rectangle triangle n circle
I am having problem in finding the solution to detect the shape of triangle, rectangular and circle as the sample of my experiments is create by my own which doesn't have a very nice rectangular shape or circle shape.
I have tried with Imaq find shape but failed to detect any of my rectangle and circle.
Anyone have experience of using this vi or have any solution for me in order to used for the detection of these three type of shape?
Big thanks in advance
(3,211 Views)
What are your inputs (images, [x, y] points, aka sparse or dense data)?
What is your expected output? Do you know it's a triangle, and do you want to know how well it fits? Or do you need to classify the shape into triangle, rectangle or circle?
(3,167 Views)
My input will be image which consists of triangle rectangle and circle as well.
My expected output is i want to classify out the shape into triangle rectangle and circle. As the application of my project is pick and place, so the coordinate of the object is to be known as well.
I tried with IMAQ detect shape but failed to get the ouput.
(3,147 Views)
Do you want help with your code?  Then you would do well to attach (all of) your code.  You should also attach an example Image (or Images).  Do you just "want an answer"?  Hire a LabVIEW Developer with IMAQ experience.
Bob Schor
(3,127 Views)
