Shapes on the same graph
That's what I said Smiley Happy
Made it for squares, anyway if you have some patience I'll change it right away
EDIT: already changed it Smiley Very Happy
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
Message 21 of 31
(1,069 Views)
Fixed a problem in the normal rectangle representation.
Also found out there is a bug in drawing the rectangle, due to using of Firstcall.
Maybe you can fix this as a training Smiley Wink
Message 22 of 31
(1,066 Views)
is there anyway of making the change to the code with the triangle, circle and rectangle on the code below. i get really confused with that new code you created where there are two different graphs
Message 23 of 31
(1,065 Views)
I can't open your vi. Please save it in another version like 2012 or 2011.
File>Save for previous version.
You want the draw rectangle function in the same graph is that what you mean?
Message 24 of 31
(1,061 Views)
Yeah, i dont want to be able to draw a square just a triangle circle and rectangle
Message 25 of 31
(1,057 Views)
Ok, ehm you want to able to draw them all at the same time?
I changed it so you just have one graph left
Message 26 of 31
(1,049 Views)
is there any way to take out the code that makes the square and just keep in the triangle, circle and rectangle? the code was alot easier to understand before the square code was added. back to like the code below but with the code changed to draw the rectangle properly
Message 27 of 31
(1,042 Views)
Yes ofcourse, then you have to delete the case structure from the square.
Message 28 of 31
(1,040 Views)
any chance you could have a go at getting some code to work for me, ive been stuck on it for ages
Message 29 of 31
(1,030 Views)
I'm sorry, I have no Labview at this computer. Tomorrow I'll have a look at it.
But in the mean time you could try some tutorials.
Message 30 of 31
(1,022 Views)
