Shared Dll unable to exit application.
My application is using a shared dll generated by labview. When I attempt to exit my applicaiton hangs. I verified a normal exit without the labview dll.  This is a statically linked lib and the module is functioning properyly otherwise.
Thanks in advance,
zeekial
(3,351 Views)
Hi zeekial,
what are you doing in your dll? Do you start parallel running processes? When do you get this behavior?
Mike
(3,326 Views)
The dll is calling shared variables that reside on vi's in a single board rio system.
(3,317 Views)
Hi zeekial,
Are you using your application in development mode or as an executable? And that's running on a PC connected to this sb rio over the network? And the application runs fine - the only problem is the shutdown?
Jeff | LabVIEW Software Engineer
(3,310 Views)
My application is an executable running on a pc connected to the sbrio over a network cable. Yes, the only problem is the shutdown issue. I've tried statically and dynamically linking to the dll and both approaches exhibit the same issue.
(3,308 Views)
What language is your app that is calling the DLL written in? Is it possible to run a debugger to find the exact call that is hanging?
(3,281 Views)
