Shared Excel Workbook does not minimize as expected.
I noticed a strange behavior Report Generation Toolkit when using an Excel file which is set to be Shared Workbook.
I have a piece of code that opens an Excel file and reads its content.
I use native RGT VIs, no modifications.
This is how I open my Excel file:
When my Excel file was not set to Shared Workbook my code opened Excel file minimized and read data properly.
When I changed Excel to be in Shared Workbook mode my Excel does open, it is minimized at beginning but as soon as RGT reaches Excel_OpenWorkbook.vi the Excel window is back from minimized to normal.
I can minimize it back programmatically, but the Excel still pops up for a fraction of a second which bothers me much.
(2,143 Views)
I prepared simple example.
Excel files are empty. The only difference is with Shared Workbook settings.
One opens minimized while other does not...
(2,100 Views)
The answer is simple -- do not use the RGT with Shared Workbooks.  Recall that the Report Generation Toolkit is designed to Generate a Report, in this case, one that adheres to the format of an Excel Workbook, using "hooks" into Microsoft Excel.  Here's a note from Microsoft:
Shared Workbooks have limitations, and one in particular is the inability to edit using Excel for the web. Therefore we highly recommend co-authoring, which is the replacement for Shared Workbooks. Create a new workbook or open an existing workbook. Then place it on a network location.
Bob Schor
(2,085 Views)
