Shared Library Interface (SLI) is not working properly in LabVIEW NXG 3.0.1
It is not longer possible to use Drag&Drop holding the Ctrl-Key to use the functions of a SLI in your GVi's.
I tested this on 2 PC's and a Virtual Machine.
I tested it on the shipped example "External Code (DLL) Execution" - Example. There is also a bug that it does not load the dll properly, so I had to choose the path to the dll manually. After that the GVI's compile correctly but I cannot use the functions in the SLI for my own GVI's (unless i copy &paste the blocks).
This is more an issue if I want to use my own Dll for my application. The workaround is now to create the GVI's in NXG 2.1, where the Drag&Drop still works, and then use those in NXG 3.0. But that is very annoying.
Felix
(3,898 Views)
Accepted by topic author schoffel
Hi Felix,
I've also seen this issue.
But you don't need the drag & drop. You can simply use in the gvi Diagram:
Projectobjects->Software->...
to insert your function.
Hans
(3,834 Views)
@Johann78 wrote:
Hi Felix,
Hans
Isn't that a bit like saying, "You don't need your indicator lights.  Just stick your hand out the window"?
Bill
CLD
(Mid-Level minion.)
(3,825 Views)
Hi Hans,
that worked for me and I did not know it is working like this now.
Thank you very much!
(3,793 Views)
You're welcome 🙂
(3,783 Views)
