Shared Variable Error
I have a problem regarding shared variable. It is at the attachment.
How can I fix this ?
Thanks ...
(4,053 Views)
The text in you image suggest several possible causes. What kind of troubleshooting did you try to narrow it down?
(4,036 Views)
I tried all of them but I could not fix it. What I created is at the attachments.
If you can help me, it would be very amazing
because this is the last part of my project
(4,015 Views)
You are not providing any useful information, for example does the error occur right after startup? (in which case you can ignore it). What did you try? What changed? Is the shared variable hosted on the PC or the RT system?
Why are your loops both spinning like crazy as fast as the system allows? Seems ill advised. What does the rest of the project do?
(3,972 Views)
