Shared Variable Not accessible Remotely
Dear all,
I have configured PSP variables in host computer and want to access it using remote computer. But remote computer only able to detect the library instead of variables. What i had did so far to troubleshoot but no luck.
1. Turn off firewall and antivirus
2. router already set port forward rules : TCP 2343, TCP 59110-59115
3. Network set to private and the network adapter of host computer set to Interface metric 1
4. Reinstall NI Distributed System Manager
5. NI PSP service locator and NI Variable engine services are both running
Below is variables show in host computer
Below is library show in remote computer, but no variables are shown.
Funny thing is I have 6 host computers. All same settings, only 3 able to connect. Another 3 computers depends on luck because initially I able to connect. After I restart computer then not able to connect anymore. May I know what else I can do to troubleshoot this issue? Please help me...
(1,112 Views)
Did you check your firewall logs in system32/logs/firewall for drops?
CLA
(1,072 Views)
I enabled the firewall log feature then restart the computer. Its show empty files. I already turned off firewall for domain, public and private profile. So should not be firewall issue right?
(1,035 Views)
I have no deeoer knowledge on nsv but are you sure you are doing it right? I would expect the correct usage to be creating the variables library on a single machine (master) It kinda looks like you deployed the libraries also to the targets?
CLA
(1,017 Views)
