Shared Variable "No Known Value" on Distributed System Manager
Hello all,
I have a simple FPGA application (image 1) on my FPGA Target cRIO-9101 and I also have a Real Time VI on the Real Time Target which I want to run always on the RT Target (Image 2).
I have created shared variables to be able to control from another computer on the same network as the RT Target, but the values on the Distributed System Manager show as "No Known Value" (Image 3).
  • I Have done "Deploy all" on the Project Explorer;
  • I have instaled on the RT Target the "Variable Client Support"
  • I have checked the IP settings and is ok.
So, I don't know what I am doing wrong or what is still missing me to do, so I ask if there is anybody who can help me to solve this problem, because I think I have tried everything.
(Images and VI on attachment - There are some Portuguese words)
Thanks in advance
(1,536 Views)
Update:
I could fix the problem with the help given in https://forums.ni.com/t5/LabVIEW/Can-not-read-shared-variable-on-cRIO-error-1950678968-nitaglv/m-p/1...
After that you might need reinstall the RT Target SW, but then it works all perfect
(1,506 Views)
