Shared Variable
Hello all:
I developer a VI with OPC Shared Variable . It run good in my developer PC.
Then package it into setup programme, intall it to another new PC.
Run vi.exe. When deploying shared variable, i got an error.
my_opc.lvlib\\127.0.0.1\my_opc deployment failed(error: -1967362042, os and network services:(hex ox 8abc7006)
(2,990 Views)
This url may help you:
http://digital.ni.com/public.nsf/allkb/1F45A4298B976F4A86257168006EA0C3
Then, when you use SV communication, you have to check :
- the network settings of the PC,
- the runtime Labview or a development Labview installed  on all PC.
I hope that it has solved the problem.
Best regards.
R. Kaszubiak
(2,924 Views)
