Shared Variables To Lib
Hi everybody,
I'm changing the attributes of a single shared variable and running the variable through the "SharedVariablesToLib.vi" to save the settings in the variable engine. I have som trouble about the time the vi uses:
With 20 variables deployed in the library it use 450 ms
With 100 variables it use 1640 ms
And finally with 710 variables it use 54100 ms
Does anyone know why it should take that amount of time for such a simple operation? Why should it use longer time with more variables deployed in the library when i'm just changing one?
LabVIEW 8.6 and DSC 8.6
Tomas
(3,244 Views)
Hi Tomas,
LabVIEW will allways have to deploy the whole library, because the variable is part of it. When you change the attributes of the variable you also change the lib. it self.
Sorry, but the only way to save deployment time is to split the library.
Best regards
Rüdiger
(3,217 Views)
