Shared variable deployment on target machine
I am trying to use network-published shared variables for the first time , (just passing data from one VI to another) everything works just great in the development environment , and works great on the dev machine when built into exe's , but , when I move the executables to the target machine i get an error 8 , file permission error , havent found anything regarding this on here or NI. I am using the Library.Deploy Library Method to deploy the variable on the target machine...
Any help would be greatly appreciated.....
Dan
(3,101 Views)
Is the shared Variable Library added or part of the .exe build?
(3,078 Views)
