Shared variables with FPGA Module
Hi everyone.
I am having some trouble passing a shared variable from RT to FPGA with my sbRIO-9651.
I am using a 32-bit Integer going from the FPGA to the RT and an Unsigned 16-Bit Integer going from RT to FPGA. The U16 Integer connects to an enum in a windows host VI.
Any ideas why I might be getting issues? I Can pass data from windows to RT perfectly fine, its just when it gets from RT to FPGA that I get build errors.
UPDATE: I have included the zip file of the project. Its a little convoluted to follow as I haven't finished modifying the code yet and it originated from a wizard, so lots of code I don't need. But the FPGA VI should be fairly clear.
(4,728 Views)
Shared variables do not work on FPGA.  You need to open a reference to the bit file you want loaded (you have to do this anyways to get your FPGA to run) and then write to the front panel controls of the FPGA VI through the FPGA Read/Write Controls (it looks a lot like a property node).
(4,707 Views)
