Shared varialble FIFO -- ensure no lost of data
      I would like to use network shared variable to send data from a VI ont the RT controller of my CompactRIO to the Host VI that runs on my computer. I did a like VI to understand the way shared variable works but I didn't find the right properties to ensure that I'm not losing the data.
Does somebody could help me with that?
(2,512 Views)
Network Streams in LV 2010 are designed for lossless data transfer.  NSV's do not guarantee to be lossless, you would have to add a data index count to a data cluster so that integrity could be verified.  There are examples of lossless tcpip RT->Windows transfer at ni.com.
Another thing to consider is that sometimes you do not need data transfer to be 'lossless' to have a good record of physical data on the rt.  In my case I use the cRIO scan engine to update IOV's at 40Hz,  I then transfer IOV data to cRIO hosted NSV's which are bound to windows hosted NSV's which in turn are set to log to a citadel database.  In effect I am getting a final 20Hz 'sampled' data stream into my DB.  Does my system guarantee that a 50ms signal transient will always get caught and logged in the DB?  No is does not, but for those kind of issues I usually rely on rt processes to catch such events and generate alarms.
(2,496 Views)
