Sharing complex data between LV applications on multiple machines
My apology tst,
I was sure I can't open the reference to the calling VI, but I have just tested it, and apparently there is no problem doing so!
So all I need to do is publish the machine name and VI path of the top level VI among all the called VIs and let them open the reference on their own!
Seems like my problem is solved! Thanks a lot guys!
Message 11 of 12
(794 Views)
@Ben wrote:
You have been doing a great job here on the Exchange. If you were inclined to be so, you would be justified to be proud of what you have been doing, BUT, somehow I don't think you will have that problem.
I assume you have mistaken "Isn't this a face you can trust?" to be part of the text.
After "Here I come to save the day" I have in fact taken to using quotes from my avatars as signatures, and that is a line used by Lucy on more than one occasion (for example, when she holds the football for Charlie to kick just before moving it so he falls on his back). Perhaps I should change its appearance to make it stand out a little more.
I am "proud" in my activity here, but you are right, I do not feel the need to be cuddled. I don't attach that much importance to this place. It's just nice to learn and to help others, and it's also fun around here.
___________________
Try to take over the world!
Message 12 of 12
(792 Views)
