Shift 1D Array
How do you shift all the elements in a 1D array by 1? I previously used 2D to 1D vi that was posted and have 3 seperate 1D arrays. Because the array starts at zero, my information is off by 1 ! I want element 1 in index 1, element 2 in index 2..... I don't use index 0 so anything can be placed there.
(4,650 Views)
Hi
Check my example for a possible approach.
Luca P.
Application Engineer
Luca
(4,650 Views)
That worked great ! Thanks for the quick response !
(4,650 Views)
Isn't this all that is required?
(4,650 Views)
😉 Yes, that's the right solution! That happens if you think the wrong way.
Luca
Luca
(4,650 Views)
