Shift Register Look-up Table (SRL) in LabVIEW FPGA
Hello. Is it posisble to implement a Shift Register Look-up Table (SRL) in LabVIEW FPGA? If yes, how can I implement it?
(3,951 Views)
two ways.
either use the xilinx tools to generate an IP core that implements a SRL and import it using a CLIP node or implement it yourself in LabVIEW FPGA.  if you do it in LabVIEW, you should consider implementing in VI scoped memory using circular buffer logic
Stu
(3,919 Views)
Try "FPGA Math->High Throughput Math->Basic Elements->Discrete Delay". That node is mapped precisely to a SRL on FPGA chip.
(3,855 Views)
Nice.  configure for dynamic.  Learn something new every day.
Stu
(3,838 Views)
