Shift value on axis on a graph
Hello. I have a program that collects data and then plots it. I would like to be able to shift the graph left or right. Just like in an oscilloscope one can shift the time axis so that the zeros intersect the blocks. I would appreciate it if someone can help. By the way I am using the XY graph indicator but if you have answers for the wave chart that will be welcome as well. Thanks in advanced.
(3,003 Views)
You could add or subtract the desired shift amplitude from the X values, as in the attached example.
CC
Chilly Charly    (aka CC)
(2,994 Views)
Or may be you just want to shift the axis scale, not the data...
CC
(2,989 Views)
