Shocked.. BUG LV 5 - LV 7.1
Well, I'm shocked... The same bug is still in the newest version (been there
since LV 5, I think).
Try it:
Make a string (constant, control indicator, it doesn't matter).
Type a few lines in it.
Make a selection like this:
go to the nth line
press shift
press the up key
press end
You now have a selection.
Press CTRL-X
LabVIEW 7.1 crashes right away.
For previous versions (note some weird characters created by a pointer
overflow):
Press CTRL-V
This bug has been reported, but it is still there. So I guess you have to
use an event structure to prevent users from using CTRL-X...
Wiebe.
(2,400 Views)
Just to give the thread a more possitive edge:
D:\lvmerc\src\source\manager\memory.cpp(1704) : DAbort: negative length = -1
in MoveBlock
$Id: //labview/branches/Mercury/dev/source/manager/memory.cpp#10 $
0x00465ED5 - LabVIEW + 0
0x004A46DE - LabVIEW + 0
0x004A4582 - LabVIEW + 0
0x005C5DFB - LabVIEW + 0
0x005C6734 - LabVIEW + 0
0x00751FA0 - LabVIEW + 0
0x009E3859 - LabVIEW + 0
0x0074A888 - LabVIEW + 0
0x0074A439 - LabVIEW + 0
0x006B9747 - LabVIEW + 0
0x00749F3C - LabVIEW + 0
0x0061AA40 - LabVIEW + 0
Wiebe.
"Wiebe@CARYA"
iNOebe.walsSPtra@carAMya.nl> wrote in message
news:412c6ff0@newsgroups....
> Hi,
there
> Try it:
> go to the nth line
> press shift
> press the up key
> press end
> Press CTRL-X
> overflow):
> Press CTRL-V
> Regards,
> Wiebe.
(2,400 Views)
Good catch! I will report this to R&D (actually myself) for review.
Jeff Peters
LabVIEW R&D
(2,400 Views)
