Shore Western Actuator Input and Output exchange with NI cDAQ
Hi, I have a question regarding the hardware connection, I am using a Shore Western Hydraulic Actuator for my test and it has its own controller (attached its hardware configuration) and I figured out that I need to sync it with the DAQ (NI cDAQ-9178) in order for both to have the same clock (same time during the test). Also I need to have one of the voltage reading from the DAQ (one coming from a wire potentiometer) to be also shared with the actuator controller as a feedback. I am using LabVIEW NXG for the DAQ Is that doable ?
I would really appreciate your help on this matter.
(2,133 Views)
Hi, I have a question regarding the hardware connection, I am using a Shore Western Hydraulic Actuator for my test and it has its own controller (attached its hardware configuration) and I figured out that I need to sync it with the DAQ (NI cDAQ-9178) in order for both to have the same clock (same time during the test). Also I need to have one of the voltage reading from the DAQ (one coming from a wire potentiometer) to be also shared with the actuator controller as a feedback. Is that doable ?
Ahmad
(2,133 Views)
(2,131 Views)
