ShortCut
I just finalized my VI however I would like to incorporate a shortcut to NI MAX to facilitate the modification of the tasks.
 Regards, Jérémie DUBOIS
(3,863 Views)
can you elaborate your request a bit clear?
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,842 Views)
In my VI I use some tasks, and i want a shortcut in my front panel to custom them.
(3,825 Views)
If you just want MAX opened, you can use the System Executive function and use a command to open C:\Program Files (x86)\National Instruments\MAX\NIMax.exe
(3,822 Views)
Thank Crossrulz, but where i can find this command ?
(3,814 Views)
Search "System Exec" on your block diagram palette and you'll find it under Connectivity >> Libraries & Execution.  I made a quick drop shortcut for this that is "cmd" since a command prompt is essentially what it does in Windows.
(3,804 Views)
